[Proj] Specify a different directory for gsb files
Ervin Oswaldo Escobar Salazar ervinoswaldoescobar at gmail.com
Wed Aug 29 02:25:54 PDT 2007
Uff.. I cannot access to the configuration of the server... cannot set
environment variables nor writing at c:\proj
Any other idea?? I am completely knocked out.
Thanks for your help.
2007/8/28, Eric Miller <EMiller at dfg.ca.gov>:
> Set the environment variable PROJ_LIB to the path where you're putting the
> GSB files.
> >>> On 8/28/2007 at 11:18 AM, "Ervin Oswaldo Escobar Salazar"
> <ervinoswaldoescobar at gmail.com> wrote:
> > Does any know how can i specify a different than the default folder
> > (c:\proj\nad) in order to cs2cs takes the gsb files when using NTV2
> datum
> > shifting method?
> > I have been testing with the NTV2 datum shifting method and it works ok
> when
> > I put my national specific .gsb file under the default c:\proj\nad
> folder
> > (as you can see, i am under windows platform). However, I need to change
> the
> > default folder for the datum files because I have no permission to write
> on
> > c:\proj. When i put the .gsb file in a diferent folder, the NTV2
> > transformation is not done.
> > Do i need to recompile again? In that case, which file or files should i
> > edit and how?
> > Thanks in advance for your help.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20070829/38511cbd/attachment.html>
