[Proj] prj to xml
Frank Warmerdam
warmerdam at pobox.com
Tue Dec 11 20:09:11 PST 2007
Gennady Khokhorin wrote:
> Hello, Frank.
> If you building gml tree what api I can use to translate it to xml?
> What routine/class can handle gml<-->prj conversion?
> Happy programming!
Gennady,
The C++ class used for this is OGRSpatialReference and it is part of
my GDAL/OGR library (http://www.gdal.org). The OGRSpatialReference
class supports translating between a variety of coordinate system
formats, including WKT (it's internal representaton), PROJ.4, GML
(weak really), and a few other esoteric options. A reasonable primer
on the services is available at:
http://www.gdal.org/ogr/osr_tutorial.html
Incidentally, this is the class uses to generate the PROJ.4 "epsg" init
file.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the Proj
