[Proj] PROJ 4.6.0 Released
Frank Warmerdam
warmerdam at pobox.com
Fri Dec 21 11:25:14 PST 2007
Folks,
There haven't been any major problems with the PROJ 4.6.0 beta1 though there
have been a few changes so I've packaged up a 4.6.0 final release:
http://download.osgeo.org/proj/proj-4.6.0.tar.gz
http://download.osgeo.org/proj/proj-4.6.0.zip
The changes since beta1 are:
2007-12-21 Andrey Kiselv <dron at ak4719.spb.edu>
* PJ_wag3.c: Added missed "lat_ts" parameter to projection description
string.
2007-12-20 Frank Warmerdam <warmerdam at pobox.com>
* pj_list.h, Makefile.am, PJ_mpoly.c: Removed mpoly projection. It
was just a dummy (no actual transformation).
2007-12-06 Frank Warmerdam <warmerdam at pobox.com>
* pj_factors.c: in the case of phi=90, the derived should be calculated
at [90-delta,90] instead of at [90,90+delta] (the same is true for -90)
http://bugzilla.remotesensing.org/show_bug.cgi?id=1605
2007-12-03 Frank Warmerdam <warmerdam at pobox.com>
* pj_transform.c: Small improvement in WGS84_ES precision to avoid
an unnecessary trip through geocentric space (eg bug 1531).
2007-11-30 Frank Warmerdam <warmerdam at pobox.com>
* add latlon and lonlat as aliases.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the Proj
