[Proj] Question about Italian conversion
Massimo De Marchi massimo at studiodemarchi.net
Mon Dec 24 01:43:16 PST 2007
I am a new user, and was performing image conversion with gdalwarp
between old Italian c.s. (Gauss Boaga) and WGS 84.
I found there is a shift (around 100m)in the conversion. I tested with
cs2cs and I have the same issue.
The coordinate conversion is the same using both EPSG 3003 or 26591, or
using the proj4 string taken form spatialreference.org
Starting with 1641163 East and 4997349 North I get
10d47'40.422"E  45d6'52.824"
in place of:
10d47'39.5"E    45d6'55.2"
What am I doing wrong?
Thanks in advance,
Massimo
