[Proj] Problem with merc projection
Antonio Volpicelli
volpicelli at oato.inaf.it
Wed Dec 26 13:27:45 PST 2007
Hi guys,
I am not sure that this is a right mailing list but probably someone can
addressing me in the right place.
I am using the Mike Adair proj4js and merc.js code .
The trasformation using cs2cs gives me different result if I use the
Mike code.
When I transform lon/lat to X/Y the Mike code give me a latitude lower
then the cs2cs of about 0.200 degrees.
>cs2cs +proj=latlong +to +proj=merc
10.6846908 41.26904150
1189414.34 5023915.99 0.00
with the Mike code
1189414.34 5052106.58
Is there someone that has the same problem?
Help will be welcome and appreciated
Antonio
More information about the Proj
