[Proj] Converting Mercator Meters to Degrees
Mikael Rittri Mikael.Rittri at carmenta.se
Fri Feb 2 03:57:07 PST 2007
I suspect your direct formula doesn't use the appropriate value for the
Earth radius.
CP>   longitude = (MMEasting / 6356752.3142) * 57.295779513082322;
CP>   OR longitude = (easting / earthRadius) * RadToDeg;
That value looks like some kind of average earth radius for a spherical
earth model.
But I think you must use the equatorial radius of the WGS84 ellipsoid,
which is
   6378137.0 meters
see, for example, http://home.online.no/~sigurdhu/WGS84_Eng.html
Best regards,
  Mikael Rittri, Carmenta, Sweden.
-----Original Message-----
[mailto:proj-bounces at lists.maptools.org] On Behalf Of Christopher Portka
Sent: den 1 februari 2007 18:43
To: proj at lists.maptools.org
Subject: [Proj] Converting Mercator Meters to Degrees
I'm trying to convert a UTM easting value to an easting in mercator
meters and then to its correct longitude.
