[Proj] Rectified Skew Orthomorphic...
Michael Childs
mike at globalmapper.com
Wed Feb 7 09:50:50 PST 2007
I am trying to use Proj4 v4.4.9 to implement RSO support as described below
from a 2004 thread, but it does not appear that the changes discussed in the
thread ever made it into Proj4. Am I missing something or did these changes
never get made? Does anyone have a copy of the code that implemented the
'gamma_c' parameter for the 'omerc' projection?
Thanks,
Mike
Global Mapper Software LLC
An update:
The forward script:
opts="+proj=omerc +a=6377298.556 +rf=300.8017 +lat_0=4 +lonc=115 \
+alpha=53d18'56.9537 +gamma_c=53d7'48.3685 +k_0=0.99984 \
+x_0=590476.87 +y_0=442857.65"
replicates the example for Borneo in EPSG #7 and
opts="+proj=omerc +a=6378206.4 +es=.006768657997291094 \
+k=.9999 +lonc=-133d40 +lat_0=57 +alpha=-36d52'11.6315 \
+x_0=818585.5672270928 +y_0=575219.2451072642 +units=us-ft"
replicates the fortran version of gctp to 0.0005 us-ft.
You can see that +gamma_c is the only difference in the usage.
I would appreciate Malaysia specs and bench values as well as more
bench values for Borneo.
Thanks.
About another weeks work to check inverse and other options and
clean up documentation.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20070207/77850c9b/attachment.html>
More information about the Proj
