[Proj] Lat-Long to Lambert Conformal Conic(2SP) transformation inaccuracy issue
Gerald I. Evenden
geraldi.evenden at gmail.com
Sun Feb 18 08:28:11 PST 2007
On Sunday 18 February 2007 5:31 am, Tonu Lukk wrote:
> Thanks for the reply. First a correction - in my original posting the
> backslashes were removed from the command line. They were actually present
> when I ran the tests. My mistake.
> It does seem to be a windows' shell problem but I can't really figure out
> what exactly is causing it.
> Two tests.
> 1.
> proj +proj=lcc +lat_1=58N +lat_2=59.333333N +lat_0=57.517553N +lon_0=24E
> +x_0=500000 +y_0=6375000 +ellps=WGS84
> Input 24E 57d31'3.19415"N gives 500000.00 6375000.10
> Input 24E 57.517553N gives 500000.00 6375000.00
> This hints that the problem lies in the command line parameters - as far
> as I understand the difference in conversion is most likely caused by
> rounding accuracy of an input value.
> 2.
> proj +proj=lcc +lat_1=58N +lat_2=59d20\'N +lat_0=57d31\'03.19415\"N
> +lon_0=24E +x_0=500000 +y_0=6375000 +ellps=WGS84
> Input 24E 57d31'3.19415"N gives 500000.00 6375098.83
> Input 24E 57.517553N gives 500000.00 6375098.72
> Obviously the problem is in command line parameters. Further testing
> showed that it (in my case) is caused by the +lat_0=57d31\'03.19415\"N
> parameter. Also tried with \" removed from the end, but with the same
> results. Somehow it is interpreted wrong.
> Any ideas why?
In this case, the precision in the conversion from DMS to fractional degree
causes the slight error. From gp
? (31+3.19415/60)/60
%1 = 0.51755393055555555555555555555555555555
Thus a test script illustrates the correction:
echo "original script"
lproj +proj=lcc +lat_1=58N +lat_2=59d20\'N +lat_0=57d31\'03.19415\"N
+lon_0=24E +x_0=500000 +y_0=6375000 +ellps=WGS84 <<EOF
EOF
echo "expanded decimal degree fraction (from gp)"
24E 57.51755393055556N gives 500000.00 6375098.72
EOF
--------------------------------- change (bit of an overkill now ;-)
which generates:
original script
500000.00 6375000.00 gives 500000.00 6375098.83
500000.00 6374999.90 gives 500000.00 6375098.72
500000.00 6375000.00 gives 500000.00 6375098.72
Now both examples yield the same answer. Your original latitude had a 6 digit
fraction where the DMS was closer to an 8 digit fraction.
The devil is in the details. :-)
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
More information about the Proj
