[Proj] State Plane Coordinate Zone 6 Conversion Help
Ed McNierney ed at topozone.com
Fri Feb 23 14:18:22 PST 2007
Matt -
I just got back in and I'm reading messages in reverse order, so the
note I just sent you is simply saying the same thing Frank already said.
	- Ed
-----Original Message-----
[mailto:proj-bounces at lists.maptools.org] On Behalf Of Frank Warmerdam
Sent: Friday, February 23, 2007 5:07 PM
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] State Plane Coordinate Zone 6 Conversion Help
Matt Bartolome wrote:
> Hello list,
> I'm trying to convert state plane coordinates from zone 6 (san diego
> county, california)  to latitude longitude and I'm having trouble.
> $ echo "6262009 1854017" | proj -I -f %.4f +proj=utm +zone=6
> +ellps=GRS80 +datum=NAD83 +units=m
> -100.1078       11.6424
> I've also tried plugging in some computed constants I found but I'm
> not sure if they are accurate.
> $ echo "6262009 1854017" | proj -I -f %.4f +proj=utm +ellps=GRS80
> +zone=6 +lat_0=32.166667 +lon_0=-116.25 +datum=NAD83 +k=0.999954142490
> -100.1078       11.6424
> I'm pretty sure the datum NAD83 is correct, as well as the GRS80
> ellipsoid. The values should be close to -116, 32.
Matt,
+proj=utm +zone=6 is not at all the same thing as california state plane
zone 6.
Perhaps you want:
echo "6262009 1854017" | proj -I -f %.4f +init=epsg:2230
-117.2246       32.7499
EPSG 2230 is "NAD83 / California zone 6 (ftUS)"
epsg:2230 looks like:
<2230> +proj=lcc +lat_1=33.88333333333333 +lat_2=32.78333333333333
+lat_0=32.16666666666666 +lon_0=-116.25 +x_0=2000000.0001016
+y_0=500000.0001016001 +ellps=GRS80 +datum=NAD83
++to_meter=0.3048006096012192 no_defs  <>
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
