[Proj] Getting Extent Using Custom Projection
Bradley Mclain bradleym06 at gmail.com
Tue Jul 10 21:24:32 PDT 2007
Sorry for being stupid but what exactly goes into the geog_data.txt file? I
have tired putting the extent of the original but this does not work.
On 7/11/07, Gerald I. Evenden <geraldi.evenden at gmail.com> wrote:
> On Tuesday 10 July 2007 11:10 pm, Bradley Mclain wrote:
> > Ok what I have done is made a custom projection and I want to get the
> new
> > extent for my data.
> > The original projection:
> > "# GDA94 / MGA zone 55
> > <28355> +proj=utm +zone=55 +south +ellps=GRS80 +towgs84=0,0,0,0,0,0,0
> > +units=m +no_defs  <>"
> > The custom projection:
> > <41002> +proj=merc +lat_ts=0 +lon_0=0 +k=1.0 +x_0=0 +y_0=0 +a= 6378137.0
> > +b= 6378137.0 +units=m <>
> > I understand that this must be done by console commands or something but
> I
> > have no idea how.
> > Brad
> If you are using proj or lproj just execute the command:
> proj +proj=merc +a= 6378137.0 +b= 6378137.0
> or
> lproj +proj=merc +a= 6378137.0 +b= 6378137.0
> I edited out all the superfluous material.  Then follow the above commands
> with longitude latitude pairs and Cartesian will be output.
> More appropriately create a file of your geographic coordinates in file
> geog_data.txt and do:
> proj +proj=merc +a= 6378137.0 +b= 6378137.0 <geog_data.txt >results.txt
> The whole religious complexion of the modern world is due
> to the absence from Jerusalem of a lunatic asylum.
> -- Havelock Ellis (1859-1939)  British psychologist
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20070711/7caa281d/attachment.html>
