[Proj] Converting to SRS:4326
Bradley Mclain bradleym06 at gmail.com
Tue Jul 17 21:38:12 PDT 2007
Thanks that was the problem, couldn't get the command to work so just used
an online calculator to do the conversion.
Thanks for the help
Cheers
Brad
On 7/18/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Bradley Mclain wrote:
> > Yes sorry to mention thats what I was doing and I got the same results
> > as you did but these do not work in mapserver as it says that the extent
> > is invalid. I'm pretty sure it has to do with the d's etc.
> Bradley,
> Ah.  Indeed you cannot use geographic values in DMS (Degrees, Minutes
> and Seconds) format directly in your mapserver extent line.  You
> can use the -f %.8f switch to produce decimal formatted values.
> eg.
> proj -I -f '%.8f' +init=epsg:28355
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20070718/000a9c2d/attachment.html>
