[Proj] Graduated equidistant projections for convenient co-ordinate transformations
Michael Ossipoff
mikeo2106 at msn.com
Mon Jul 30 22:27:05 PDT 2007
This lists main topic is solutions for co-ordinate transformations. But
this posting isnt off-topic, because its about co-ordinate transformations
too: I claim that, for data maps in atlases, the transformation from the
maps X & Y co-ordinates to the latitude/longitude co-ordinates should be
easy and convenient for everyone, and I suggest a solution that I havent
read mentioned anywhere.
But Id also appreciate it if someone could tell me of a general map
projections discussion list, or any Internet mailing list, newsgroup or
other forum where this posting would be more appropriate.
When atlases have data maps showing such things as climate, vegetation and
population, it could be of some interest to the reader to find out exactly
where the map is saying the boundaries of the zones are. With nearly all
data maps, determining the latitude and longitude corresponding to a point
on the map involves calculation. Regrettably that can be an inconvenient
amount of calculation, as is the case with, for instance, the Lambert
azimuthal equal area map--a common projection for data maps.
For some projections, such as Mercator, Miller, and the pseudocylilndricals,
the calculation is more feasible, because it's only necessary to calculate
the latitude from the point's Y co-ordinate, the points distance from the
map's equator. But most atlas users would like to get an accurate
measurement without even having to do that.
So it's obvious that a data map should use an equidistant projection, a
projection in which the latitude and longitude vary linearly with distance
north or east on the map. Then anyone could easily determine the
geographical co-ordinates of a point on the map.
Some would answer that the data map zone boundaries are approximate anyway.
But it would still be better to not add position-guessing error.
Of course the measurements would be even easier if the projection is
cylindrical, with meridians and parallels straight and perpendicular to each
other.
So I suggest that the best projection for data maps would be the cylindrical
equidistant. Below Ill suggest an improvement on that projection.
Because a cylindrical projection is centered on the equator, while a conic
is centered on a parallel in the mapped region, the use of a cylindrical
projection would mean more distortion, but that's an acceptable price for a
data map on which positions are more easily measured.
Of course if one needed the low-distortion advantages of a conic, such as
easy and relatively accurate distance measurements, then one might want to
use a conic equidistant, as a compromise between easy position-measurement
and low-distortion advantages. But I suggest that the cylindrical is usually
better, because surely the positions of the zone boundaries are the most
important information in a data map, and their ease of measurement is
all-important. With a conic, longitude measurement isn't as easy and
accurate as with a cylindrical.
What I'm saying is intended to apply to all data maps, whether showing the
world, a continent, a country, or a state or province.
But of course a cylindrical equidistant world map shape-distorts at some
latitudes, usually the near-polar latitudes. And the radically different
scales in the two dimensions can complicate distance-measurement. But
there's no reason why the north-south scale has to be uniform over the whole
range of latitudes: Why not specify dividing parallels (say, every 10
degrees, for instance), and have the distance from the map's equator vary
linearly with latitude, but at a different scale, between each pair of
dividing parallels. So, using the 10 degree example, the north-south scale
between 0 and 10 degrees latitude would be equal to the geometric mean of
the east-west scales at 0 and 10 degrees latitude. And the north-south
scale between 10 and 20 degrees latitude would be equal to the geometric
mean of the east-west scales at 10 and 20 degrees latitude
and so on for
each 10 degrees of latitude.
That's what I'm calling a graduated equidistant projection. Determining
geographic co-ordinates from map position would be as easy as with an
ordinary equidistant projection, but shapes and directions wouldn't be
visibly distorted, and scales would be more nearly the same in all
directions. The map would have, to some degree, the advantages of a
conformal projection, while retaining the easy position measurement of an
I propose the use of the graduated equidistant cylindrical map for all data
maps. But, if one desires the low-distortion advantages of a conic, then Id
propose the graduated equidistant conic for data maps of ontinents,
countries, states and provinces, with the cylindrical used only for world
maps. As I said, I consider easy position measurement to be the most
important property of a data map, which is why Id use the cylindrical for
all data maps.
Why not use recommend Bonne for continents? With curved parallels and
meridians, accurate determination of longitude would be especially
inconvenient. And Bonne has more scale variation than conic--and distances
are probably the most often-measured quantity on maps.
I don't necessarily claim to be the first advocate of graduated equidistant
projections, but I've never found one in an atlas, or anywhere else. And
I've never read any mention of them.
When the only calculation needed for position-measurement is that of
calculating the latitude based on the distance from the maps equator, as in
the case of the Mercator or a pseudocylindrical map, some would be willing
to do that calculation.. For many purposes the advantages of conformality
would be desirable--uniform scale in every direction at any particular
point, and more accurate shapes and directions. So, for someone who doesnt
mind calculating latitude from the Y co-ordinate, the Mercator might be a
better choice than the graduated cylindrical equidistant. Of course the
latter projection can be regarded as a very rough beginning of an
approximation to the Mercator.
Likewise, someone who is willing to calculate latitude from Y co-ordinate
might prefer the conformal conic to the graduated equidistant conic, for
the same reason. Or maybe not, because that calculation involves more work
with the conformal conic than with the Mercator.
Of course, even someone willing to calculate latitude from Y co-ordinate
might often prefer the convenience of a graduated equidistant projection,
with which very little calculation is needed.
To save space on the page, one could use a somewhat smaller north-south
scale in one or more dividing-parallel sections in the extreme north and
south parts of the map. Those regions arent where most people would
usually need to measure distance and direction anyway. Of course one could
do that with the Mercator too, using the Mercator for all latitudes except
those where the expansion seriously uses up page-space. There, the Mercator
would be replaced by cylindrical equidistant or graduated cylindrical
equidistant, or maybe a grafting of the Miller there. Id prefer those
combinations to the ordinary Miller projection because it would keep
Mercators properties in the most important parts of the map.
Someone might want to combine the easy position measurements of an
equidistant with the beauty and round appearance of an world elliptical map.
So, for that person, how about an equidistant elliptical projection. It
would be a compromise between two extreme equidistant projections--the
cylindrical equidistant and the sinusoidal. Parallels are spaced equally and
each is divided uniformly. And the parallels lengths are determined by the
maps elliptical shape. It would resemble Mollweide, but with equidistant
parallels. Longitude measurement, with the curved meridians, wouldnt be as
easy as it would be with a cylindrical projection. For that reason, speaking
for myself, Id prefer the graduated equidistant cylindrical for data maps.
Michael Ossipoff
More information about the Proj
