[Proj] Graduated equidistant projections for convenient co-ordinate transformations
Michael Ossipoff
mikeo2106 at msn.com
Tue Jul 31 04:47:59 PDT 2007
Prof. Strebe--
You wrote:
>Easily converting between map coordinates and spherical coordinates is one
>reason to choose a projection. When a mapmaker decides that's the most
>important
>reason, the mapmaker does just what you suggest. Generally the mapmaker
>decides other factors are more important.
I want to emphasize that I was only suggesting those equidistant projections
for data maps, whose purpose is to show where, for instance, certain zones
of vegetation are.
Mike Ossipoff
More information about the Proj
