[Proj] Why use pj_inv() and pj_fwd() instead of pj_transform() ?
fabrice martin
fabrice_martin2 at yahoo.fr
Sun Jun 3 12:19:14 PDT 2007
>The principle reason is that a prime meridian can easily be compensated for
>with simple modification of the central meridian (+lon_0).
In
that case, shouldn't EPSG definitions be modified, in order to use
+lon_0 instead of +pm ? For example, French Lambert projections are
defined with "+lon_0=0 +pm=paris". Wouldn't it be better to use simply
"+lon_0=2.33..." ? It would enable pj_inv, pj_fw and pj_transform to
return similar results.
Regards,
Fabrice.
_____________________________________________________________________________
Ne gardez plus qu'une seule adresse mail ! Copiez vos mails vers Yahoo! Mail
More information about the Proj
