[Proj] Re: wgs point (lat-lon 'NMEA' to N-E 'metric')
Massimo Di Stefano
massimodisasha at yahoo.it
Wed Mar 28 13:21:16 PDT 2007
Hi Hamish
Hi Eric
thanks for your time !
sorry for my distraction :-(
i know that i must divide the minute /60
... i modified my string to :
var="4051.1749|01415.5317"; lat="`echo \"(${var:2:2}.${var:5:2}${var:
7:2} /60)"|bc -l`" ;lon="`echo \"(${var:13:2}.${var:16:2}${var:18:2} /
60)"|bc -l`";echo "${var:0:2}$lat ${var:10:3}$lon"
40.85291500000000000000 014.25886166666666666666
- are this coordinates good for a proj conversion ?
if it is ...
can you suggest me a proj string to change from degres to metric
coordinates ?
again:
... the proj conversion produce as result
a LAT - LON point
but grass reads the points (v.in.ascii)
as
LON - LAT
so i need to revert the order of coordinates ($Lat $Lon) > ($Lon
$Lat)
(right?)
p.s.
i prefer do not use gpsd, so i can write a module without external
dependencies.
i know that gpsd is a really good software for this purpose!
Il giorno 28/mar/07, alle ore 14:52, Hamish
<hamish_nospam at yahoo.com> ha scritto:
> as for
>> 4051.1749 N --> 40 51.1749 N --> 40.852915 N
> if data is fixed width you might add "cut" to awk,
> lat_deg=`echo "$input" | cut -c1-2`
> lat_min=`echo "$input" | cut -c3-9`
> lat_hem=`echo "$input" | cut -c11`
> lat_dm="${lat_deg}d${lat_min}${lat_hem}"
> $ echo $lat_dm
> 40d51.1749N
> which proj might be happy with.
More information about the Proj
