[Proj] ED50 from C API
Roger Oberholtzer
roger at opq.se
Thu Mar 29 23:32:20 PDT 2007
On Thu, 2007-03-29 at 09:05 -0700, Eric Miller wrote:
> I don't know about the "esri" file, but you have two different ellipsoids and no information to convert between the different models. Don't you need a datum or towwg84 parameter for the ED50 definition? I think the ED50 towgs84 parameters are missing because there is more than one candidate. See, http://crs.bkg.bund.de/crs-eu/
> There isn't really much difference between using cs2cs and pj_transform. The init strings are the same. Same for proj and pj_fwd/pj_inv.
I have since tried a few ED50 definitions to see which is closest to the
target locations:
"+towgs84=-87,-98,-121 " // "EUROPEAN 1950, Mean"
"+towgs84=-87,-96,-120 " // "EUROPEAN 1950, Western Europe"
"+towgs84=-84,-107,-120 " // "EUROPEAN 1950, Portugal &
Spain" (best)
"+towgs84=-86,-98,-119 " // "EUROPEAN 1979"
The best is "+towgs84=-84,-107,-120 ", which gets me to within 5 meters.
Still too far, but better.
It still remains a mystery to me how anyone actually uses the esri file
when it is quite often incomplete. To the point it does not work at all.
Especially for a conversion as 'big' as one used for all roads in Spain.
Perhaps proj needs its own file that contains complete working
definitions? proj is a great library. But without proper definitions is
is less useful than it could be. I understand the complexity of the
thing since so many things can be converted into so many things,
resulting in a zillion combinations. But there must be something
possible. Or is the solution staring me in the face and I just don't see
it? Do all users of proj make all the definitions locally (read
"reinvent the wheel")?
> >>> On 3/29/2007 at 3:40 AM, Roger Oberholtzer <roger at opq.se> wrote:
> > Let me ask this another way:
> > proj has definitions for many conversions in the 'esri' file that that
> > it provides. These definitions appear to be used as changes from some
> > default initial settings. I say that as many say very little. The rest
> > must be specified elsewhere. When I want to add a new conversion via the
> > C API, I expect I could start by looking for an existing definition in
> > the 'esri' file. As the list can probably tell, each time I find I need
> > to add a new conversion, I never get it right and then ask the list.
> > Each time the corrections seem (to me) to be different. So, I am missing
> > some important part of the puzzle. Does no one else on the list use the
> > C API very much?
> > On Wed, 2007-03-28 at 16:04 +0200, Roger Oberholtzer wrote:
> >> I would like to convert WGS84 lat/longs from a GPS receiver into
> >> northings and eastings in ED50, fixed in UTM zone 30N. I have tried the
> >> following, but the results are always 100-150 meters off from what I
> >> expect. What have I missed? I based this in the ESRI file in proj 4.4.9
> >> Initialization (error checking removed here for clarity):
> >> // From GPS WGS84
> >> fromProj = pj_init_plus( "+proj=latlong "
> >> "+ellps=WGS84 "
> >> "+towgs84=0,0,0 "
> >> "+no_defs"):
> >> // To ED50
> >> toProj = pj_init_plus( "+proj=utm "
> >> "+ellps=intl "
> >> "+zone=30 "
> >> "+units=m "
> >> "+no_defs"):
> >> The call for each location:
> >> lng = LONG * DEGREE_TO_RADIAN;
> >> lat = LAT * DEGREE_TO_RADIAN;
> >> alt = 0; // We do not give this a height
> >> pj_transform(fromProj, toProj, 1, 0, &lng, &lat, &alt);
> >> For example:
> >> Input WGS84: lat=37.57508059 lng=-0.93032997 alt=0.00000000
> >> Obtains: Easting=682771.459 Northing=4160841.260
> >> But I am expecting: Easting=682876.090 Northing=4160892.020
> >> There is a difference in location of 116.293 meters.
> >> The error is in the initialization step. I suspect it is something that
> >> is not in the ESRI file that I need to add when doing this from the C
> >> API. But what?
> > Roger Oberholtzer
> > OPQ Systems / Ramböll RST
> > Ramböll Sverige AB
> > Kapellgränd 7
> > P.O. Box 4205
> > SE-102 65 Stockholm, Sweden
> > Tel: Int +46 8-615 60 20
> > Fax: Int +46 8-31 42 23
> > Proj mailing list
> > Proj at lists.maptools.org
> > http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
Roger Oberholtzer
Ramböll Sverige AB
Kapellgränd 7
P.O. Box 4205
More information about the Proj
