[Proj] pj_transform performance issue
Herve Baille
hb at meteorage.com
Mon Nov 12 08:32:01 PST 2007
Hi Frank and Grek
Thanks for your answers.
> I'm quite surprised, and I don't know why you would see such a
> performance
> problem.
Me too and I have also the feeling that it does not make sense.
But it is like this, as if pj_transform remember the address of the
coordinates array, to compute (or not) some projection coefficients to
speed up the calculation?
We can easily update our program to pass coordinates by address.
> But I will say that if trans() takes the x,y values by value
> (as shown), then the calling variables will not be changed. If you want
> the values actually altered outside trans() they need to be passed by
> reference.
The example is a reduction of a real case and does not make sens as is.
It is just for testing.
> I will note that it is highly desirable to pass many points to
> pj_transform() at once. Transforming points with one per call
> is relatively expensive.
Effectively, a single call with a 100000 coordiantes array is computed
in 2 seconds!
Unfortunately, we cannot do this in our context, but this is our problem.
Thanks again
Hervé
Hervé BAILLE <herve.baille at meteorage.com>
Software development manager
Sté Météorage
2 av Angot
64053 PAU
France
CATS support <support at meteorage.com>
More information about the Proj
