[Proj] epsg parameters
Wed Apr 2 13:15:45 PDT 2008
Paul Kelly wrote:
> I think it's in general a bad idea to include datum transformation
> information without any user interaction, because many users have the
> misconception that there is somehow a "correct" set of parameters which
> will always give them accurate results. When of course, as we've seen
> discussed on this list many times, accurate datum transformation is very
> much a localised thing: a transformation that gives accurate results in
> one region of a country may give very inaccurate results in another
> region, and a transformation that covers the whole country is in general
> not very accurate anywhere.
There's also the issue that being "accurate" may be less important
than being consistent with whatever data you're using.
