[Proj] patch: fallback to 7/3 param transform when gridshift transform fails
Craig de Stigter
craig.destigter at koordinates.com
Tue Apr 15 17:19:13 PDT 2008
Hi list
We came across some out-of-grid geometries when transforming from EPSG:27200
(New Zealand Map Grid). The results returned included INFs and NANs, which
was hardly useful.
As a solution I wrote a patch for the pj_datum_transform function in Proj.
The patch first tries to convert coordinates using the gridshift approach if
available, but on failure will fall back to using the appropriate 3- or
7-parameter transform.
The Bugzilla page linked from http://www.remotesensing.org/proj/ is not
working, so I've attached the patch to this message for your perusal.
Comments are welcome.
Regards
Craig de Stigter
Koordinates Ltd (formerly One Track Mind).
PO Box 1604, Shortland St, Auckland, New Zealand
Phone +64-9-966 0433 Fax +64-9-969 0045
Web http://www.koordinates.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080416/bb265d59/attachment.html>
Type: text/x-diff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080416/bb265d59/attachment.diff>
More information about the Proj
