[Proj] problems with windows include
Frank Warmerdam
warmerdam at pobox.com
Fri Apr 25 06:17:15 PDT 2008
Matthias Schneider wrote:
> Hi all,
> I used the the proj.4 some time ago. Now I want to use it in a VC++
> project were I need windows includes like "windows.h" and there is the
> problem. If I do that, ther are some errors:
> * redeclaration of "PVALUE"
> * different use of "LPWSTR"
> Is there a possibility to use both - windows includes and proj.4 at the
> same time? Without the windows includes, there are no errors - but I
> need it :(
Matthias,
The proj_api.h include file should not conflict with windows.h, though it is
known that projects.h can. So, just include proj_api.h, which is intended
to be the public interface to PROJ.4.
If you really need projects.h for some internal thing ... well good luck.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the Proj
