[Proj] projection of Madagascar
OvV_HN
ovv at hetnet.nl
Tue Apr 29 10:01:59 PDT 2008
Clovis wrote:
> I have been quickly through the archive but didn't find any topic on this.
> I have a projection issue concerning Madagascar.
There are no good nor usable alternatives for the Laborde projection.
Using the Oblique Mercator you'll get decimeters of error within the
Madagascar territory.
One example from my software:
Laborde Madagascar:
lat = -16d 11m 23.280s; lon = 44d 27m 27.260s;
lat0 = -18.9; lon0 = 46d 26m 14.025s;
x0 = 4e5; y0 = 8e5; k0 = 0.9995; Az = 18.9;
international 1924 ellipsoid
-> x, y = 188333.848, 1098841.091
Oblique Mercator approximation with the following parameters:
lat0 = -18.9; lon0 = 46d 26m 14.025s; lonc = lon0;
x0 = 4e5; y0 = 8e5; k0 = 0.9995; alfac = 18.9; gamma = alfac;
-> x, y = 188333.847, 1098841.111
(angles in degrees wrt Greenwich, lengths in meters)
These differences may seem small, but wait until you get farther away
from the central line.
See also section 1.3.6.1 "Laborde projection for Madagascar", EPSG
Guidance Note 7-2, version April 2008.
There you can also find omerc examples with an error of several decimeters.
More information about the Proj
