[Proj] Re: projection of Madagascar - EPSG
Noel Zinn
ndzinn at comcast.net
Wed Apr 30 03:32:37 PDT 2008
Formerly the EPSG carried only 29700 which was the Oblique Mercator
approximation to the Laborde, which (it so happened) exactly duplicated the
results from the ESRI algorithm (about which I know no details). 29700 is
now gone since February 2007 (deprecated or superseded, I'm not sure of the
exact EPSG terminology). In its place are 29701 (which is - in my opinion -
is the "true" Laborde based on IGN, a handwritten Laborde manuscript and
other French sources) and 29702 (which is the former 29700. This has been
of some interest to me since my company works in Madagascar.
Noel Zinn
-----Original Message-----
[mailto:proj-bounces at lists.maptools.org] On Behalf Of Clovis
Sent: Wednesday, April 30, 2008 3:33 AM
To: Melita Kennedy; PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Re: projection of Madagascar
Tanks for the details and for the quick answers,
Indeed laborde projection is not implemented by default in the esri
projection library.
I retrieved this laborde projection approximation from friend working in
a GIS company for long times. I guess is the the one that is used by
most governement institution and companies in the country.
This approximation does produce satisfactory results (good match with
various source of dataset). But i can't say if there decimeter offset as
I'm not working at that scale.
Hope to see the laborde be implemented in Esri product and all other
software.
From the various comments, should i conclude that there is still no
accurate laborde projection definition and transformation?
Does the 29701 or 29702 should be used as the most correct laborde
approximation? What is the best one: 29701 or 29702?
Clovis Grinand
Melita Kennedy a écrit :
> Dear Clovis,
> That ArcGIS definition is an approximation; it's not the true Laborde
> implementation and is not guaranteed to give correct answers.
> We do plan to try to implement Laborde in the future, but it just
> hasn't made it to the top of the list yet.
> Melita Kennedy
> ESRI Product Specialist
>> Date: Tue, 29 Apr 2008 19:27:48 +0300
>> From: Clovis <clovis.grinand at ird.fr>
>> Subject: [Proj] projection of Madagascar
>> To: proj at lists.maptools.org
>> Dear list,
>> I have been quickly through the archive but didn't find any topic on
this.
>> I have a projection issue concerning Madagascar.
>> Historically there is one dedicated projection called "Laborde", using
>> International 1925 ellipsoïd with others parameters.
>> From what i know it has been approximate with an oblique mercator
>> projection and another called hotine oblique mercator.
>> Then, I use ArcGIS usually for my application and want slowly to move
>> towards R and QGIS, espacially to transform point coordinates in R
>> (spTransform). The big problem is that none of three have the same
>> projection definition and do display large offset when projecting GPS in
>> WGS84 to "Laborde".
>> From the projection definition, you will see below that there is some
>> agreement (lat of origine, scale factor, false easting, false northing,
>> azymuth) but some are completly different : longitude of origine and
>> prime meridian etc.
>> As I consider ArcGIS definition and transformation to be the right one
>> (works well!), my question are:
>> - Is the EPSG parameters up to date?
>> - How can i tune the parameters to obtain the same coordinates that with
>> arcGIS.
>> - Why lonc and not lon_0 ? (lon_0 does not give anything good)
>> I hope I m not missing something obvious.
>> Clovis
>> # EPSG 29700 Via R
>> print(CRSargs(CRS("+init=epsg:29700")))
>> [1] " +init=epsg:29700 +proj=omerc +lat_0=-18.9 +lonc=44.10000000000001
>> +alpha=18.9 +k=0.9995000000000001 +x_0=400000 +y_0=800000 +ellps=intl
>> +towgs84=-189,-242,-91,0,0,0,0 +pm=paris +units=m +no_defs"
>> # EPSG 29700 Via GQIS
>> +proj=omerc +lat_0=-18.9 +lonc=41.76277083000001 +alpha=18.9
>> # Laborde projection in ArcGIS
>> laborde
>> Projection: Hotine_Oblique_Mercator_Azimuth_Center
>> False_Easting: 400000,000000
>> False_Northing: 800000,000000
>> Scale_Factor: 0,999500
>> Azimuth: 18,900000
>> Longitude_Of_Center: 46,437229
>> Latitude_Of_Center: -18,900000
>> GCS_Tananarive_1925
>> Remarks:
>> Angular Unit: Degree (0,017453292519943299)
>> Prime Meridian: Greenwich (0,000000000000000000)
>> Datum: D_Tananarive_1925
>> Spheroid: International_1924
>> Semimajor Axis: 6378388,000000000000000000
>> Semiminor Axis: 6356911,946127946500000000
>> Inverse Flattening: 297,000000000000000000
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Proj mailing list
More information about the Proj
