[Proj] Transverse Mercator south-oriented projection support?
Gerald I. Evenden geraldi.evenden at gmail.com
Fri Aug 8 13:49:58 PDT 2008
On Friday 08 August 2008 1:10:11 pm Neil Robinson wrote:
> Hi there,
> Any idea whether there are plans to implement this stuff:
> http://lists.maptools.org/pipermail/proj/2000-September/000099.html
> Or is there a work-around I could use?
> I would greatly appreciate being able to use this projection in my work
> with qgis.
> Thanks,
Groan!
There is no need to modify the library routines as all that is needed is to
switch around the x-y and signs of the lat-lons.
I would just use +proj=tmerc and put some added '-' flags to juggle the I/O.
But that's somebody else's job as I only work on the library.  ;-)
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
