[Proj] installation question: proj_api.h
Markus Neteler neteler at osgeo.org
Tue Aug 12 14:52:09 PDT 2008
Heather,
On Tue, Aug 12, 2008 at 11:01 PM, Heather M. Yager
<heather.yager at gmail.com> wrote:
> Hi!
> I don't yet have experience with PROJ4, but I must install it on SuSE in
> order to run MapServer with projection support. The problem: when I
> install proj from an RPM (command I used: "yast -i
> proj-4.4.9-1.guru.suse93.x86_64.rpm") it appears that the installation
> was successful - I can locate proj, I can type "proj" at the command
> line (and receive "Rel. 4.4.9, 29 Oct 2004" back).
You also need to install
 proj-devel-4.4.9-1.guru.suse93.x86_64.rpm
which contains proj_api.h and some more relevant files.
Hope this helps,
Markus
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
