[Proj] Re: Proj Digest, Vol 51, Issue 2 - axis rotation issue
Neil Robinson
halfhaggis at gmail.com
Wed Aug 13 08:22:32 PDT 2008
Gerald I. Evenden wrote:
> On Wednesday 13 August 2008 4:58:50 am you wrote:
>> I think it's my fault. I'd had latitudes as S20; S30; etc. and
>> should've put the negative in.<br>
> My goodness, that make a lot of difference!
>> <br>
>> It looks to me that I simply need to multiply the outputs by -1, but
>> I'm loath to do that because I don't understand the underlying
>> mathematics that calculates the projection. <br>
>> Is it really that simple? I could use the "-m" flag and set it to -1,
>> but is that wise?<br>
>> It appears to give me the correct output:<br>
>> <br>
>> ~$ proj +proj=tmerc +ellps=WGS84 +lon_0=27 -m -1 Desktop/proj<br>
>> -55660.46 -0.00<br>
>> -54820.34 1105896.37<br>
>> -52324.06 2212444.34<br>
>> -48243.45 3320218.65<br>
>> -58652.24 2897715.76 <br>
>> <br>
>> Can you advise?<br>
> You have a most strange grid system where the south pole is oriented to the
> top of the map. I suppose it makes a difference to someone living in the
> southern hemisphere but it is a bit odd when compared to most grid
> orientations.
Don't ask me -- I just live here! I would have been a lot less
frustrated if the powers that be could've just kept north at the top.
> All you are doing is rotating the x-y (easting-northing) axis by 180 degrees
> and this can, as you empirically determined, be done my using the '-m -1'
> option.
> As to whether an axis rotation option is libproj4's responsibility or the
> applications program's (proj4, lproj, etc.) responsibility and thus a "-"
> option or "+" option respectively is now open for debate.
Indeed. As it stands, qgis, which allows configuration of a custom
projection using proj4 parameters, doesn't appear to support the -m flag
or have an equivalent flag or setting I could use.
Since I started this whole investigation to get qgis to work properly,
my fight is still not over. At least I can measure distances now, which
is my most important requirement.
I'll see what the qgis people have to say. Thanks for your time
> Any comments from the maptools group?
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080813/e3892fef/attachment.vcf>
More information about the Proj
