[Proj] Extended range TM usage
Gerald I. Evenden
geraldi.evenden at gmail.com
Sun Aug 24 19:08:03 PDT 2008
I am finishing up the revised transverse Mercator section of libproj4's manual
which includes three additional versions of the projection that give an
extended longitude range for the projection. These version persist in being
singular at the equator and 90 degrees from the central meridian. Hopefully,
I may soon obtain a copy of Lee's work and include the Ultimate version.
The old Taylor series version (tmerc) of TM is shown to be quite adequate for
cadestral applications as demonstrated by comparisons with the expanded
versions, That is, it has sub-millimeter accuracy within all longitude zones
of standard applications that I am aware of.
At the current time I consider the work on the extended version academic and
of little practical application for the following reason: scale error of TM
beyond an easting of about 400km (approximately 3.5 degrees longitude at the
equator) would appear too large to make the projection useful in any
application other than general mapping. If general mapping is the application
then using the spherical form of tmerc should be adequate---especially for
small scale maps. The problem of the singularity of the projection at
(+-90,0) is not a problem because the distortion is so severe at the right
and left edges the sides can be clipped.
My question is can anyone supply a rational reason for the practical use of an
elliptical TM projection with extended longitude range. The explanation
should discuss how the projected coordinates are used and how the error
factor is handled in application of the coordinates (like determining
distance between points, azimuth, etc.). Of course, how precise do you
expect such measurements to be?
I would like to include some practical applications for using the added
projections.
Thank-you.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
More information about the Proj
