[Proj] polar stereographic coord
Eric Miller
EMiller at dfg.ca.gov
Wed Aug 27 11:25:19 PDT 2008
You can't project an ascii grid with proj. It only works with coordinates. Additionally, the "proj" command only does forward or inverse projections. You'd need to use "cs2cs" to convert between two coordinate systems. However, I think gdalwarp might be able to handle projecting the data.
>>> On 8/27/2008 at 9:20 AM, Adriana Huerta-Casas <ahuerta at awi-bremerhaven.de>
wrote:
> Hi,
> I'm new using proj4 and I can't really figure out how to do this properly:
> I need to convert data given in polar stereographical coordinates (from
> BEDMAP, 71S lat true scale,0E central meridian,5km nominal grid spacing)
> to cartesian coordinates. The input file is ascii and contain headers.
> I'm after a file x,y,data.
> The first lines of the file to read and convert are:
> ncols 1200
> nrows 1000
> xllcorner -3000000
> yllcorner -2500000
> cellsize 5000
> NODATA_value -9999
> -9999 -9999 -9999 -999 ...
> I'm doing the follwing:
> cat icethic.asc | proj +proj=stere +lon_0=0 +lat_0=-90 +lat_ts=-71
> +ellps=WGS84 +datum=WGS84
> but I'm wondering how to write a file and read the headers.
> Thanks a lot!
> adriana
More information about the Proj
