[Proj] "Double ellipsoid" case?
Mikael Rittri
Mikael.Rittri at carmenta.com
Mon Dec 1 01:43:41 PST 2008
Noel,
I haven't checked your results, but there is no reason to expect that the two results would be the same.
As I see it, Ellipsoid Mercator is one projection, and Sphere Mercator is a different one.
Each one is internally consistent, but the two are not the same. That is, since the formulas
are different, the (Easting,Northing) values are not the same for the same (Lon,Lat). But
for each projection, you can use its inverse to get exactly back to the original (Lon,Lat).
The Ellipsoid Mercator is exactly conformal while Sphere Mercator is only approximately conformal
(if you regard the ellipsoid as the true shape of the Earth). I think the maximal angle distortion
for Sphere Mercator is 0.2 degrees, so for visual display it is hard to notice.
Since the projections are distinct, we should not expect that analoguous calculations done
in their projected planes should give identical results.
So, the situation is similar to the French truncated Lambert Conformal Conic, which is
not exactly conformal, and is a different projection than the true Lambert Conformal Conic.
It is tricky to create WKT to represent the Sphere Mercator projection together with an ellipsoid datum.
But that is a failure of WKT, not of the Sphere Mercator. One way to express it in WKT has
been suggested by Martin Desruisseaux of GeoTools, another way by Melita Kennedy of ESRI.
See the August 2008 archives for the MetaCRS mailing list,
http://lists.osgeo.org/pipermail/metacrs/2008-August/thread.html .
And it is not only Google that uses spherical projections. So does the National Snow and Ice Data Center, USA.
ftp://sidads.colorado.edu/pub/ppp/conf_ppp/Haran/HDF-EOS_vs._GeoTIFF__GIS_Problems_when_Projection_and_Datum_Spheroids_are_Different.pdf
I think it is unfortunate that EPSG insists that a spherical projection can only be used together with a spherical datum, because
a) it is not true,
b) spherical datums do not exist for the Earth (http://lists.maptools.org/pipermail/proj/2008-August/003667.html).
Best regards,
Mikael Rittri
Carmenta AB
Box 11354
SE-404 28 Göteborg
Visitors: Sankt Eriksgatan 5
SWEDEN
Tel: +46-31-775 57 37
Mob: +46-703-60 34 07
mikael.rittri at carmenta.com
www.carmenta.com
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Noel Zinn
Sent: den 30 november 2008 06:05
To: 'PROJ.4 and general Projections Discussions'
Subject: RE: [Proj] "Double ellipsoid" case?
Not that Frank is responsible for the geodesy and cartography in Google Maps (or their abuse therein), but the phrase "the resulting lat/long coordinates are intended to be treated as WGS84 after that" so troubles me that I am sympathetic to Cliff's sentiments. So, let's quantify the offense with an experiment that anyone can duplicate, perhaps in Proj4 (I work in Matlab).
Consider the following Mercator grid parameters defined on both WGS84 and the Google Sphere (whose radius equals the semi-major axis of WGS84): CM = 95W, FN=FE=0. That's all we need.
Now consider at point at 30N / 95W. That's somewhere near Houston, Texas, where I live. Convert to Mercator in both systems. Then traverse to the NE about 141km in both systems by adding 100km to both the Northing and Easting (in Mercator). Convert the resulting Mercator coordinates back to geographicals (lat / lon).
Here's what I get for WGS84: 30N / 95W is N3,503,549.84350437m / E0m with a point scale (Mercator is conformal) of 1.15470053837925 and at the end of the traverse the geographicals are 30-46-29.63568N / 94-06-06.06498W.
For the Google Sphere the results are: 30N / 95W is N3,482,189.08540862m / E0m with a point scale of 1.15373388324025 and at the end of the traverse the geographicals are 30-46-43.56897N / 94-06-06.06498W.
Pardon the excessive precision; it's just what I get. And I hope that I haven't blundered in my haste to respond. Perhaps someone can confirm.
Interestingly, the longitudes are the same, but the latitudes are very different (more than might be accounted for by the scale differences, a cartographic subtlety likely beyond the ken of most Google Maps users anyway). I don't believe the resulting lat/long coordinates can be treated as WGS84 at all.
Noel Zinn
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Clifford J Mugnier
Sent: Saturday, November 29, 2008 8:15 AM
To: PROJ.4 and general Projections Discussions
Frank:
Ah, there's a BIG difference between the true coordinate system relations of geodesy used by national governments and one cooked up by an ignoramus at Google Maps that did not know what they were doing ... I guess there's a lot of that going around, too.
I suppose even twits help contribute to keep knowledgeable consultants in business.
Cliff Mugnier
LSU
From: proj-bounces at lists.maptools.org on behalf of Frank Warmerdam
Sent: Fri 28-Nov-08 10:52
Subject: Re: [Proj] "Double ellipsoid" case?
support.mn at elisanet.fi wrote:
> Hello,
> I just started to think about a situation where there might be a double
> ellipsoid case.
> 1) projection uses ellipsoid A independently
> 2) datum shift uses ellipsoid B
> Is this possible to be handled with proj.4? Since there is only one
> ellipsoid definition available
Janne,
PROJ.4 does not currently handle this situation conveniently. One special
case is where the projection uses a particular ellipsoid, but datum shifts
should treat the corresponding lat/long values as being WGS84. In that
special case you can use +nadgrids=@null to effectively say the datum shift
to WGS84 is a no-op.
I have at times contemplated having a way of having a datum/ellipsoid
definition used for datum shifting purposes that is independent of the
normal ellipsoid used by the projection functions but I have not pursued it.
Clifford J Mugnier wrote:
> I've seen a few projections and datums in my day, and I've never come
> accross that. For there to be a different ellipsoid of reference for a
> projection than there is for a datum is a contradiction in terms.
Cliff,
The very common case we see a lot these days is the google maps mercator
projection. The mercator calculations are done based on a particular
spherical earth model, but the resulting lat/long coordinates are intended
to be treated as WGS84 after that.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20081201/afb61101/attachment.html>
More information about the Proj
