[Proj] Re: "Double ellipsoid" case?
Gerald I. Evenden
geraldi.evenden at gmail.com
Wed Dec 3 11:27:22 PST 2008
On Wednesday 03 December 2008 1:43:19 pm Christopher Barker wrote:
> >> The practical consequence is that they do not have a conformal
> >> projection; hence local distances measured from a point are not quite
> >> uniform in all directions,
> measuring distance is a problem with Mercator anyway -- the scale varies
> with latitude -- a lot more that difference between a sphere and an
> ellipsoid.
> One thing that IS absurd is that Google maps puts a scale bar on every
> map -- even the whole earth scale, where it is essentially meaningless.
Frankly, it is silly and misleading to put a scale bar on any map. Even for a
conformal map a scale bar is superfluous because the scale issue only applies
to an infinitely small segment of the map. Attempting to make a measurement
over any finite distance is subject to error that is ever increasing with
distance.
The *ONLY* method of measuring distance is with geodesic software and knowing
the geographic coordinates of the points in question.
Yes, people with continue to put scale bars on maps but *NEVER* use anything
more precise than your knuckles or finger span when measuring distances with
one. That will remind you of the limitation of such a tedius and meanless
cartographic icon.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
More information about the Proj
