[Proj] Google Earth Accuracy
Andrew Williams
AWilliams at rapidmap.com
Wed Dec 10 20:35:46 PST 2008
Thanks Duncan. That "docking" scenario was how the system was sold to me by the developer of the hardware (Navcom).
Guess the brochure sounds better than the technically correct description;)
So just to make sure ITRF varies over time compared to WGS84 based on tectonics, correct?
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Duncan Agnew
Sent: Thursday, 4 December 2008 5:24 AM
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Google Earth Accuracy
Since I am in the crustal-motion business I want to correct the previous
posting about ITRF. This is "space-based" only in the sense that it uses
data from outside the Earth (GPS and other satellites, along with
distant
radio sources). It was not designed with space use in mind. Since ITRF
and
WGS84 are both space-based in this sense, they align closely: after all,
the center of the Earth and the rotation pole are both non-arbitrary.
ITRF was designed to be an ultraprecise reference frame for measuring
motions
of the Earth as a whole, and of different parts relative to each other.
Since
the frame is designed to be fixed relative to the velocities of all the
tectonic plates, averaged over the whole Earth, any particular point
will
have time-varying coordinates in this frame--as is is in fact true for
any
frame not tied to a particular plate (WGS-84 included), though many
softwares
do not take account of this. The people who develop and update ITRF are
working at the millimeter level.
Two "plate-fixed" frames are NAD (at least east of the Rockies), and
EUREF
(for Northern Europe). Rather weirdly, Australia has chosen not to
define
a local frame, even though it has a plate all to itself.
For more on ITRF, see http://itrf.ensg.ign.fr/
Duncan Agnew
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
