[Proj] Re: WGS84 Lat Lon to XYZ convercion
Alekos Ntermaris
ntermaris at iqsoft.gr
Fri Feb 1 01:24:21 PST 2008
The problem is that using the pj_fwd function i get the same results as
the input ( lon , lat) and not XYZ....
Thanks Alex
O/H support.mn at elisanet.fi έγραψε:
> Hello,
> It is not totally clear, what is the problem? That is how lat/lon
> projection works: it takes the lat and long coordinates and converts
> them directly to X and Y, your results are totally ok??
> If you want to shift your local coordinates to WGS84 and then project
> them to lat/lon X-Y; you should tell the proj-4, that your coordinates
> are not in WGS84. In that case you will have 2 datums: the source datum,
> which is your local datum and that is shifted from WGS84; and the
> destination datum, which is the same as the WGS84. Then you first call
> the pj_transform() to do the datum conversion between those two datums
> and then you do the projection to lat/lon projection calling pj_fwd() in
> the destination datum and projection.
> Regards: Janne.
> Alekos Ntermaris <ntermaris at iqsoft.gr> kirjoitti:
>> I want to convert long ,lat , h coordinates to X,Y, Z to WGS 84
>> I Tried the definition of WGS84
>> +proj=latlong +ellps=WGS84 +datum=WGS84 +no_defs
>> and having data
>> l:20.6390537809385
>> f:39.3094039129052
>> h:523.563059728303
>> calling pj_fwd
>> the results
>> x:20.6390537809385
>> Y:39.3094039129052
>> The same as input...
>> Any suggestion for this transformation????
>> Thanks
>> Alex
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
More information about the Proj
