[Proj] WGS84 to Minnesota State Plane South
Arno Gerretsen
arno at agerrius.nl
Thu Jan 3 01:03:23 PST 2008
I am trying to convert some data for a friend from WGS84 lat/lon to
Minnesota State Plane South. I use the proj4 library for that, but the
results do not match with some of the control point data he gave me. So
I am wondering if I maybe did something wrong in my code. Here is the
code I used:
PJ *prjState = pj_init_plus("+proj=lcc +lat_0=43 +lon_0=-94
+lat_1=45.21666666666666666666666666666666666
+lat_2=43.783333333333333333333333 +x_0=800000 +y_0=100000 +ellps=GRS80
+datum=NAD83 +units=ft +no_defs");
PJ *prjWGS = pj_init_plus("+proj=latlong +ellps=WGS84 +datum=WGS84");
double x[1], y[1], z[1];
int err;
x[0] = -93.242251388888888888888888888889 * DEG_TO_RAD;
y[0] = 44.887752777777777777777777777778 * DEG_TO_RAD;
z[0] = 0.0;
err = pj_transform(prjWGS, prjState, 1, 1, x, y, z);
With this code and for the lat/lon values listed in the code, I get the
following State Plane coordinates returned: 2821057.917382 1017161.112401
While the reference data says it should be: 2821052.29398607,
1017159.04559559
As you can see the difference is a few feet. Can anybody tell me if I
have done something wrong in my code, or should I doubt the quality of
the reference data :)?
Thanks,
Arno
More information about the Proj
