[Proj] PROJ as embeddable framework for Mac OS
Hal Mueller hal at mobilegeographics.com
Fri Jan 4 15:36:58 PST 2008
I need to reconfigure PROJ as an embeddable framework for Mac OS.
This is so that I can make a drag-and-drop installable app (one that
does not need an installer, as is recommended by current Apple
guidelines).  The binaries posted on the Kyngchaos site are built as
system-wide frameworks.
The Kyngchaos port has this tantalizing note in the ReadMe.rtf:
> Before linking (or maybe after linking) the framework copy's
> install_name and library paths should be changed using
> install_name_tool.  A handy relative path that can be used is
> @executable_path, this is the location of the app executable.   So
> a path to the framework within the app package would be
> @executable_path/../Frameworks/PROJ.framework/PROJ.
> You would have to change the id of the framework, and the
> dependencies of the framework that are also included in the app
> package, to be relative paths.  This can get messy.
> Currently there is an additional consideration: the data folder.
> It is normally hardwired into the library, but there is also an
> environment variable to override that.  It's up to the programs
> using PROJ to take care of this.
What exactly do I need to pass as arguments to install_name_tool?
What -id am I working with?
What are the "messy" dependencies referred to?
What change do I need to make to manage the data folder?  What's the
default as built?
This would be a lot easier to understand if the build instructions
were included in the framework.  Or are they now included if I do a
configure/build on the Mac?
Hal
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080104/1c781220/attachment.html>
