[Proj] PROJ as embeddable framework for Mac OS
Hal Mueller
hal at mobilegeographics.com
Fri Jan 4 21:12:07 PST 2008
On Jan 4, 2008, at 9:00 PM, William Kyngesburye wrote:
> As a small example, if you bundle the GDAL and PROJ frameworks.
> GDAL also links to PROJ, so you would have to change the references
> in the bundled GDAL to use the relative path to the bundled PROJ.
> The more interdependent frameworks you bundle, the more changes
> within those bundled frameworks are needed.
This sounds like an argument for using @executable_path in the
frameworks in that case.
There are certainly cases where you want to install one copy of the
Maptools frameworks in /Library, for all apps to share. But there
are other situations where you want to be independent of the
installed environment. So perhaps 2 different targets are needed--
one embeddable target, and one for system-level installation.
For the archives: data directory ends up being /Library/Frameworks/
PROJ.framework/Resources/proj, for the current iteration anyway.
Resources/Info.plist, and the proj files themselves (in
PROJ.framework/Resources/proj), are world-writeable, and owned by the
user who installed them, with a group of "wheel". I don't see this
as much of a security risk, however.
Thanks for all of your work!
Hal
More information about the Proj
