[Proj] Lambert tangent form to Lambert secant form
Clifford J Mugnier
cjmce at lsu.edu
Sun Jan 13 14:56:43 PST 2008
The Lambert Conformal Conic with one standard parallel defined with a latitude of origin and a scale factor at origin less than one is a secant Lambert. There are very few truly tangent Lambert Conformal Conic zones extant in the entire world. The difference is what you have a problem with is likely just some algebra. See Chapter 3 of the current "Manual of Photogrammetry" published by the American Society for Photogrammetry and Remote Sensing for some algebraic clues to your conundrum.
C. Mugnier
Louisiana State University
From: proj-bounces at lists.maptools.org on behalf of RICHARD Didier
Sent: Sun 13-Jan-08 12:18
To: proj at lists.maptools.org; gdal-dev at lists.osgeo.org
Subject: [Proj] Lambert tangent form to Lambert secant form
Hi all,
I am facing a bug in the MapInfo driver of GDAL that might need some
modifications of PROJ.4. The bug is two fold :
- MapInfo driver only supports 1SP LCC when building the CoordSys string.
Before, I implement an algorithm that modify LCC 1SP parameters to LCC 2SP
parameters. I would like to know whether someone on the list has already
implemented such a code. Another point is how to wrap that in GDAL (I
address this question to those who are on both list);
- When I use a SRS definition with both nadgrids and towgs84 parameters in
a PROJ.4 string, the later is not taken into account. Therefore, a WKT
string of such a SRS lacks the TOWGS84 block. As a consequence, the
MapInfo driver is not able to code the datum correctly (104 is written
which is the WGS84 datum). I would like to suggest to modify
pj_datum_set.c to keep storing towgs84 values even when nadgrids have been
encountered. The idea is to keep the datum_type has PJD_GRIDSHIFT in order
to keep precise coordinates transformation with grid and to parse the
towgs84 (from line 113). I don't know if there are known or already
debated issues on that, but I would like to know whether this idea is
correct or not.
Any comments/suggestions ?
Sincerely,
didier
RICHARD Didier - Chef du pôle technique du Géoportail
2/4, avenue Pasteur - 94165 Saint Mandé Cedex
Tél : +33 (0) 1 43 98 83 23
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080113/5ff45a05/attachment.html>
More information about the Proj
