[Proj] proj-4.6.0 and BETA2007.gsb
Frank Warmerdam
warmerdam at pobox.com
Fri Jan 18 10:49:59 PST 2008
Oliver Eichler wrote:
> Hi,
> I need a little help here. I am using proj4 with the BETA2007.gsb
> correction coefficients for Germany.
> On one machine I do this with proj4-4.5 and get the expected result.
> export PROJ_DEBUG=10 will log that the file is loaded and read.
> On another machine I use pro4-4.6 and correction fails. export
> PROJ_DEBUG=10 will log nothing.
Oliver,
I'm not aware of any change in handling datum shift files in 4.6 vs
4.5. I would suggest you carefully review your PROJ_LIB setting in
the two environments. If everything still checks out, perhaps you can
describe the exact command you are using,and make the .gsb file available
so others can try the same thing.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the Proj
