[Proj] Installing Proj on a Mac
David Caress
caress at mbari.org
Thu Jul 3 15:00:42 PDT 2008
Naiara,
It is possible to install proj and GDAL on Mac OSX using the open
source package manager fink:
http://www.finkproject.org/
The finkcommander GUI application makes specifying and installing
packages fairly painless. You may need to set fink to use "unstable"
distributions to get the most recent releases.
I hope this helps,
Dave
Fink installs packages in /sw, so you will need to add /sw/bin to
your path.
On Jul 3, 2008, at 2:17 PM, Naiara Pinto wrote:
> Dear all,
> I have a question about a relatively simple thing..I need to
> install Proj on a Mac. I tried two things:
> 1) donwload the tar file to /usr/local and do:
> ./configure
> make
> make install
> 2) download the tar file to a local folder /users/naiara/library
> and do:
> mkdir proj
> ./configure --prefix=/users/naiara/library/proj
> make
> make install
> Either way I didn't get any error messages, but when I type proj I
> get the message "command not found". I suspect I might need to add
> an extra line to my .bashrc file, but I am not sure what it should
> be. I have a Mac OS 10.4.11 and I am trying to install Proj 4.6.0.
> My real goal is to install GDAL, so I am wondering what the best
> procedure is to make sure that GDAL can link to Proj.
> Any help would be greatly appreciated.
> Thanks,
> Naiara.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
David W. Caress
Senior Research Specialist
Monterey Bay Aquarium Research Institute
7700 Sandholdt Road
Moss Landing, CA 95039
caress at mbari.org
http://www.mbari.org/~caress/
Phone: 831-775-1775
Fax: 831-775-1620
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080703/ccf7108b/attachment.html>
More information about the Proj
