[Proj] how to convert between long-lat-depth coordinates to Cartisian coordinates
support.mn at elisanet.fi
Tue Jul 8 01:21:15 PDT 2008
> I need to convert data from longitudinal,latitudes and depth coordinates
> to the Cartesian Coordinates. what is the command to use?
Are you using proj-4 as a library or just wanting to convert some coordinate
data file to projected coordinates?
There is the "cs2cs", wihich can be used to convert coordinates
http://proj.maptools.org/man_cs2cs.html
Basicly what ever, just follow the documentation that was included in the
proj-4 package.
Regards: Janne
More information about the Proj
