[Proj] (no subject)
Frank Warmerdam
warmerdam at pobox.com
Tue Jul 29 22:36:51 PDT 2008
usha regadi wrote:
> hello
> give me procedure to perform inv projection operation to convert
> the coordinates from x,y to (lambda, phi)
> regards
> usha
Usha,
I think you need to give more context to get a good answer. Do you want
to do it with commandline utilities? C API? Do you just want the math?
What projected coordinate system are you interested in? I'll assume
you mean projected easting,northing by x,y and longitude,latitude by
lambda,phi. If that is so, perhaps a commandline example for a particular
projection would be helpful.
proj -I +proj=utm +zone=11 +ellpse=WGS84 < in.dat > out.dat
in.dat might contain a value like:
400000 3730000
and then out.dat will be written as:
118d4'44.85"W 33d42'18.962"N
In the above command, the -I means inverse (ie. projected to geographic rather
than geographic to projected), and +proj=utm +zone=11 +ellps=WGS84 defines the
coordinate system.
Keep in mind, the quality of the answer you get does bear some relation to
the quality of the question.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the Proj
