[Proj] FWTools and Proj: Installation
Conor O'Donoghue theconor at yahoo.com
Tue Jun 10 21:54:29 PDT 2008
Thanks Paul, (Frank and Hamish also)
Your suggestion seems to work well.
Conor
----- Original Message ----
From: Paul Kelly <paul-grass at stjohnspoint.co.uk>
To: PROJ.4 and general Projections Discussions <proj at lists.maptools.org>
Sent: Friday, June 6, 2008 10:44:30 AM
Subject: Re: [Proj] FWTools and Proj: Installation
On Fri, 6 Jun 2008, Conor O'Donoghue wrote:
> Hello Frank,
> The example you gave me is just what i had in mind.
> I typed (cut-paste) your example exactly but still got an error.... as follows
> ERROR 1: Translating source or target SRS failed:
> '+proj=merc
Might be that the 'single quote' characters don't work on Windows and you
need to use "double quotes".
Paul
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080610/03924d9c/attachment.html>
