[Proj] Re: Comments of tmerc, etmerc and ftmerc errors
strebe at aol.com
strebe at aol.com
Thu Jun 12 12:34:15 PDT 2008
Thanks for running these tests.
Quoting:
Extended geographic range usage of any conformal projection is a contentious issue as
any resultant grid system has sufficiently large scale errors as to make the
Cartesian usage of the grid very questionable.
This is true of any projection. It is true that conformal projections carry an inevitable disproportion of areas, but that's not related to scale error.
Regards,
-- daan Strebe
Two testing grids were made on tmerc, etmerc and ftmerc: in a geographic range
of 0 to 6 degrees longitude by 0 to 84 degrees latitude and 0 to 500km
Easting to 9,700km Northing. The most apparent problem is that for
reasonable demonstration the results should be presented as contour maps of
the errors but inclusion of same is not possible in this email list.
A simple summary can be made: in the lat-lon tests tmerc maintained an
accuracy of <0.7mm (as would be expected occurred at the equator) and
comparison of etmerc and ftmerc was always less than 1micron. In the
Easting/Northing test, tmerc failed dismally at 21 meters at about 58degrees
longitude/84.78 degree latitude. Again, ftmerc and etmerc maintained
agreement to within 1micron.
I believe it is quite safe to say that tmerc remains the projection of choice
for UTM applications: adequate accuracy performance and best computational
speed. Note that the lat/lon test was for 12 degree zones and thus tmerc is
would appear suitable for what I understand of the 10 degree zones used for
some Canadian province grids.
As for extended range, I will probably check the agreement of etmerc and
ftmerc over extended range but this is of lesser priority. Extended
Cartesian usage of the grid very questionable. Usage of conformal maps for
global mapping is very questionable because of the distortion. Normal
Mercator persists only because of its usefulness in rhumbline navigation
which is probably fading due to GPS. Lastly, equal-area mapping is far
preferable for thematic mapping as it at least give a better perspective of
the area extent of regions that is, in most cases, more important that an
often poor preservation of regional shape.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
-----Original Message-----
From: Gerald I. Evenden <geraldi.evenden at gmail.com>
To: PROJ.4 and general Projections Discussions <proj at lists.maptools.org>
Sent: Thu, 12 Jun 2008 9:17 am
Subject: [Proj] Comments of tmerc, etmerc and ftmerc errors
Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080612/4c634de7/attachment.html>
More information about the Proj
