[Proj] True North Angle
Gerald I. Evenden geraldi.evenden at gmail.com
Mon Jun 23 16:58:47 PDT 2008
On Monday 23 June 2008 7:17 pm, support.mn at elisanet.fi wrote:
> > Hello,
> > Does anyone know the formula to calculate the deviation angle between
> > true north and Universal Transverse Mercator grid north?  Thanks.
> > Willy Hersman
> Hello,
> There is a way to avoid any specific calculations and make an universal
> routine to do that (if you are using proj-4 as a library). You need first
> your position on the map in lat/lon coordinates. Lets say this is P1.
A simpler alternative:
If you are using the libproj4 library there is the function:
int proj_factors(PROJ_LP lp, PROJ *P, double h, struct PROJ_FACTORS *fac)
where:
lp is the geographic coordinate that you want the factors
P is the previously initialized projection
h: if non-zero is a small difference to use to determine partial differentials
     normally use 0.
fac: is a structure containing (from lib_proj.h):
struct PROJ_FACTORS {
    struct PROJ_DERIVS der;
    double h, k;    /* meridinal, parallel scales */
    double omega, thetap;   /* angular distortion, theta prime */
    double conv;    /* convergence */
    double s;       /* areal scale factor */
    double a, b;    /* max-min scale error */
    int code;       /* info as to analytics, see following */
the above value "conv" is what you are interested in.
If your data is in x-y space do:
	proj_factors(proj_inv(xy, P), P, 0., *facs);
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939)  British psychologist
