[Proj] True North Angle
Hersman, William
willy.hersman at conocophillips.com
Tue Jun 24 09:23:47 PDT 2008
Thanks to all for the helpful responses. It looks like this simple
call to proj will work fine for what I need.
Willy
-----Original Message-----
[mailto:proj-bounces at lists.maptools.org] On Behalf Of Gerald I. Evenden
Sent: Monday, June 23, 2008 8:47 AM
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] True North Angle
On Monday 23 June 2008 11:52 am, Hersman, William wrote:
> Hello,
> Does anyone know the formula to calculate the deviation angle between
> true north and Universal Transverse Mercator grid north? Thanks.
> Willy Hersman
How accurate to you want? lproj -V does a reasonable job for
convergence for
*any* projection.
lproj +proj=utm +zone=31 +ellps=WGS84 -V
#Universal Transverse Mercator (UTM)
# Cyl, Sph
# zone= south
# +proj=utm +zone=31 +ellps=WGS84
#Final Earth figure: ellipsoid
# Major axis (a): 6378137.000
# 1/flattening: 298.257224
# squared eccentricity: 0.006694379990
2 45 <----------------------------- entered
value
Longitude: 2dE [ 2 ]
Latitude: 45dN [ 45 ]
Easting (x): 421184.70
Northing (y): 4983436.77
Meridian scale (h) : 0.99967638 ( -0.03236 % error )
Parallel scale (k) : 0.99967638 ( -0.03236 % error )
Areal scale (s): 0.99935287 ( -0.06471 % error )
Angular distortion (w): 0.000
Meridian/Parallel angle: 90.00000
Convergence : -0d42'25.715" [ -0.70714305 ] <-------
Max-min (Tissot axis a-b) scale error: 0.99968 0.99968
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
