[Proj] libproj4 recall notice
Gerald I. Evenden
geraldi.evenden at gmail.com
Sat Jun 28 08:58:08 PDT 2008
There has been a correction to the tmerc and, of course, UTM which is now
available in release:
lbp4.3_080628.tar.bz2
on the web page:
http://members.verizon.net/~gerald.evenden/proj4/
The correction applies to all previous versions of the tmerc function
regardless of release, proj, proj4, etc. This change also affects any other
software which relies upon the precious versions of proj.
The degree of the changes is in the millimeter range (and equvalent effect in
the seconds). Comparison with non-proj cm values show only occasional 1cm
differences.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
More information about the Proj
