[Proj] Proj4 InitString for ISG
ARMSTRONG Jonathan Jonathan_ARMSTRONG at rta.nsw.gov.au
Thu Mar 13 21:23:47 PDT 2008
Is anybody able to provide me with the string to pass to proj4? I would
like to be able to transform coordinates to and from ISG, for all zones
relating to NSW, Australia (I think zone 56 is the main one). I've been
able to find the WKT, for zone 56/1 at least, which is:
PROJCS["AGD_1966_ISG_56_1",GEOGCS["GCS_Australian_1966",DATUM["D_Austral
ian_1966",SPHEROID["Australian",6378160.0,298.25]],PRIMEM["Greenwich",0.
0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",300000.0],PARAMETER["False_Northing",5000000.0
],PARAMETER["Central_Meridian",151.0],PARAMETER["Scale_Factor",0.99994],
PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
Problem is, I'm not sure how to convert this to a proj4 init string.
Can anyone help please?
IMPORTANT NOTICE: This e-mail and any attachment to it are intended only to be read or used by the named addressee. It is confidential and may contain legally privileged information. No confidentiality or privilege is waived or lost by any mistaken transmission to you. The RTA is not responsible for any unauthorised alterations to this e-mail or attachment to it. Views expressed in this message are those of the individual sender, and are not necessarily the views of the RTA. If you receive this e-mail in error, please immediately delete it from your system and notify the sender. You must not disclose, copy or use any part of this e-mail if you are not the intended recipient.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080314/2c947ae0/attachment.html>
