[Proj] projection adding request
Oliver Christen
oliver.christen at camptocamp.com
Thu Mar 20 00:08:45 PDT 2008
Thank you,
I will check there.
Kind regards
Oliver
> Oliver Christen wrote:
>> I would like to know if there is a procedure to ask for a projection
>> definition to be added to the epsg file distributed with the proj
>> package.
> Has the projection already been added to the EPSG database? If not,
> you can submit a change request via:
> http://www.epsg.org/Comms/Comment.asp
> Glynn Clements <glynn at gclements.plus.com>
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
