[Proj] Re: To handle geographic info from HDF5 formated Satellite Data
Aydin agerturk at gmail.com
Thu May 8 03:56:40 PDT 2008
Thank you for response.
if I use your suggestion, for example pixel (1000,1000);
longitude = -25 + 0.560648 * 1000 = 5581.48
latitude = 75 - 0.560648 * 1000 = -5531.48
So, it is not possible.
I do not have problem converting projected space to geographic space using
proj lib. My problem is how can calculate the distance from the corner using
below parameters than I can convert those to lat/lon.
Best Regards,
Aydin
