[Proj] Transverse Mercator algorithm with good accuracy/speed trade-off?
support.mn at elisanet.fi
Sat May 24 14:12:33 PDT 2008
> The tmerc of Proj4 is efficient. But it has millimeter accuracy only out to 6° of longitude from the central meridian...
1) The most easy way is to make sure never be futher than 6° away from the central median.
or
2) You could implement a floating central median (let's call it "ftmerc"), which would automatically shift as your longitude shifts. Let's say in steps of 1 degree or less. Not at all difficult to implement. And most of "tmerc" routines can be reused.
or
3) Are we talking about UTM...
Regards: Janne
More information about the Proj
