[Proj] Transverse Mercator algorithm with goodaccuracy/speedtrade-off?
Mikael Rittri
Mikael.Rittri at carmenta.com
Mon May 26 04:24:43 PDT 2008
Many thanks for all good advice. This is quite a friendly
and knowledgeable mailing list.
I have looked at Dozier's paper now (thanks to Melita Kennedy
for the link), and a summary of Poder-Engsager (thanks to
daan Strebe).
Actually, I had hoped that the Snyder/tmerc approach (or should
I say Gauss approach) could be improved with just one or two more
extra terms in the series expansions. But my understanding
from Dozier's background text (and from Clifford Mugnier's mails
in the January 2003 archives), is now that it takes quite at lot
of extra terms to get just slightly wider zones of accuracy.
On the other hand, I find it hard to believe that Dozier's
iterative algorithm is faster than the Krüger formulas from 1912
<http://www.lantmateriet.se/upload/filer/kartor/geodesi_gps_och_detaljmatning/geodesi/Formelsamling/Gauss_Conformal_Projection.pdf <http://www.lantmateriet.se/upload/filer/kartor/geodesi_gps_och_detaljmatning/geodesi/Formelsamling/Gauss_Conformal_Projection.pdf> >
As a simple comparison, I tried to count the number of
transcendental function calls (TFCs) that will be made at
run-time. I am counting sin() and cos() of the same argument
as one TFC, and likewise for sinh() and cosh(). I have also assumed
a few simple optimizations (for example, multiple-angle formulas
can be used instead of evaluating sin(2t), sin(3t), sin(4t), ...).
My results are (no warranties expressed or implied):
Num. of TFCs forw. inverse
tmerc 1 1+m (m = number of iterations in pj_inv_mlfn, usually 1 or 2).
Krüger 6 6
Poder-Engsager 7 ? (see footnote)
Dozier 6+6n 6+4n (n = number of iterations in cnewton, at least 1).
So I would expect Krüger and Poder-Engsager to have about the
same speed, and Dozier to be at least twice as slow. But of course,
the ESRI people may have done clever optimizations of Dozier's
algorithm.
For my own part, though, I think I may try to speed
up my Krüger implementation a little more.
Again, many thanks for all advice.
Footnote: For Poder-Engsager (recommended by daan Strebe),
I did not find the original source, only formulas for the
forward direction given in
http://www.fofodala.dk/projekter/9sem/2004_Flaadestyring_Himmerlands_Elforsyning.pdf <http://www.fofodala.dk/projekter/9sem/2004_Flaadestyring_Himmerlands_Elforsyning.pdf> ,
where credit is given to
Knud Poder and Karsten Engsager:
Some Conformal Mappings and Transformations
for Geodesy and Topographic Cartography,
KMS (Kort & Matrikelstyrelsen, Denmark) 1998.
Mikael Rittri
Carmenta AB
Box 11354
SE-404 28 Göteborg
Visitors: Sankt Eriksgatan 5
SWEDEN
Tel: +46-31-775 57 37
Mob: +46-703-60 34 07
mikael.rittri at carmenta.com
www.carmenta.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20080526/79ccbf9c/attachment.html>
More information about the Proj
