[Proj] New libproj4 release
Gerald I. Evenden geraldi.evenden at gmail.com
Sun Nov 9 10:22:02 PST 2008
As promised, the new version of libproj4 is available at:
http://members.verizon.net/~gerald.evenden/proj4
Besides adding inverse to Aitoff, Winkel Tripel, Hammer, etc., the new
initialization proj_initstr() is available, and the convergence sign of lcc
is fixed.  Obviously, patches to ancillary files (lib_proj.h, ...) are also
involved.
Added text in manual.pdf describing most of the changes.
Remember, any program that uses the new proj_init.c can use run-line input
such as:
	"+proj=poly ellps=clrk66"
In addition to having the initialization of
     proj_initstr("proj=utm zone=20 south")
any sting element in the array method of proj_init may have multiple blank
separated arguments.
Again, a reminder, the '+' at the beginning of a contrl keyword is optional
and ignored by the proj interpreter.  Requirement of the + is a function of
how the application program is collecting the control keywords.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
